2001 Daewoo Lanos Help
SHELLYBLAFAS
Engine Performance problem
2001 Daewoo Lanos 4 cyl Front Wheel Drive Automatic
My question is my 2001 dawoo lanos has trouble starting I have to turn the ignition about 4 times before it starts, then when I start it when I press the gas pedel it wants to go but it doesnt unless I press the pedel to the floor what can cause the two problems?????
Jun 7, 2008 at 7:46 AM
MYAK
  • 7 POSTS
check your crankshaft sensor. I had a similar problem
Jun 10, 2008 at 1:44 PM
