2000 Daewoo Lanos took to carwash,wont start
MARK CURL
Electrical problem
2000 Daewoo Lanos 4 cyl Front Wheel Drive Automatic ? miles
wont start
Oct 6, 2010 at 6:02 AM
  • 75,988 POSTS
Cranks but will not start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Oct 6, 2010 at 11:35 AM
