2000 Daewoo Lanos no start- problem
83,000 MILES • 4 CYL • FWD • AUTOMATIC
DAMIENK
2000 Daewoo Lanos- 83k, head gasket(timing belt,water pump) changed at about 75k. Ran fine up until this point:The vehicle began bogging down on acceleration from stop or low speed. I would floor the gas pedal and the car seemed stuck, -then after a few seconds- it would seem to catch up and run fine. We drove a short distance (2 miles) and then decided to return home. The car then wouldn't start. I changed the fuel filter, checked spark plugs, crank and cam sensors were cleaned, checked for spark, battery load at 10.1 v during start(but tried fresh battery too), set at tdc and rotated crank manually to check for anything internally broken. checked all fuses and fuel pump relay. I have fuel, air, and spark- engine turns over but doesn't start- even with starting fluid, and no codes reported with my scantool. What could be wrong?
Sep 6, 2010 at 9:09 AM
  • 75,988 POSTS
Double check the valve timing, timing belt could have slipped
Sep 6, 2010 at 9:13 AM
DAMIENK
[quote:6d081e88b4="rasmataz"]Double check the valve timing, timing belt could have slipped[/quote:6d081e88b4]
I have checked the timing marks each time I have tried to start it, taking it to tdc ech time- no slips.
Sep 7, 2010 at 9:49 AM
  • 75,988 POSTS
I have fuel, air, and spark- engine turns over but doesn't start- even with starting fluid, Doing this the engine should fire up till the fluid is gone-that's if you're getting spark and the valve timing is correct
Sep 7, 2010 at 10:14 AM
