2000 Daewoo Lanos no fire no spark no service sooon lite wi
15,999 MILES • 4 CYL • 2WD • AUTOMATIC
JEFF BROWN
no start no fire and service lite wont come on
Apr 6, 2010 at 11:02 PM
  • 75,988 POSTS
Hi jeff brown, Welcome to 2carpros and TY for the donation
Pick your symptoms below and get back with me asap.
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch/clutch switch and ignition switch assuming the battery and connections are good.
Apr 7, 2010 at 6:54 AM
