2000 Daewoo Lanos heating
2000 DAEWOO LANOS
IANROB61
Air Conditioning problem
2000 Daewoo Lanos Engine Size unknown Front Wheel Drive Manual 48000 miles
when i select any settings on the heater it always still comes out of the front and not the windscreen or the floor no matter what position the switch is in its still the same have you got any answers please
Mar 31, 2008 at 10:39 PM
PRODRIGU
  • 26 POSTS
check for a vacuum leak under the hood first, you should be able to trace the vacuum from the firewall back to its supply, usually at the intake manifold. If you can't find a leak under the hood, look under the dash, the problem maybe that the vacuum supply hose to your system maybe leaking or unplugged to the component that is switching the door. if its not leaking, disconnect the line and suck on it to make sure the diaphram in the component is not leaking, it should hold the suction, if it doesn't hold replace the component
May 18, 2008 at 3:02 AM
