Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Daewoo
Lanos
Emission
EVAP
2000 Daewoo Lanos evap
2000 DAEWOO LANOS
75,000 MILES • 4 CYL • FWD • AUTOMATIC
KASUAL
MEMBER
1 POST
i have check engine, evap system
Mar 27, 2008 at 3:32 PM
PRODRIGU
MEMBER
Check your gas cap, normally the cause of that problem, make sure you put it on tight after fueling up and may need to get it pressure checked to make sure the cap is holding pressure
May 18, 2008 at 2:57 AM
Add image or video
Ask a new question
Engine won't start
Engine has low power
