2000 Daewoo Lanos engine compression
26,000 MILES • 4 CYL • FWD • AUTOMATIC
DANEOK
this car recently had the head replaced due to meltdown of cam journals. someone else done the work and now the car wont run. timing marks are lined up. i did a compression test and came up with a range of 50 to 60 lbs. is that too low?
Aug 5, 2008 at 12:20 PM
BLACKOP555
  • 10,386 POSTS
thats a bit low should be in the 80s at least.
ill have to get back on the specs with that.
you getting spark and fuel?
Aug 5, 2008 at 2:27 PM
