I have changed the master and slave clutch cylinders and it now builds pressure but still will not shift i don't get it any help would be great
Jan 9, 2009 at 6:43 AM
✓Experienced Mechanic
Did you properly bleed the system after you installed the M/C and the slave-if so -you have a problem with the clutch assembly.
Jan 9, 2009 at 6:56 AM
APRILBALLMAN
MEMBER
yes i think i bled it properly had someone pump then hold clutch then opened bleed valve. But nothing was wrong when the slave went out.
Jan 9, 2009 at 11:09 AM
Did you bleed the slave/servo? If so get helper to step on the clutch a few times, while you look at the slave push rod is it moving and engaging the clutch fork.
