2000 Daewoo Lanos
TXFALLENANGEL
Engine Mechanical problem
2000 Daewoo Lanos 4 cyl Front Wheel Drive Automatic
ok my daewoo will not stay running.... at 1st it started with a crank no start we replaced the ignation coil plugs and wires.... the car will now start but will not stay running.... I am at a loss and need help. What should we try next?
Jun 21, 2008 at 9:46 AM
BMRFIXIT
  • 19,053 POSTS
Check for code s
check for pending codes
check fuel pressure
check idle air control system
check for strong spark at the plugs
Jun 23, 2008 at 11:02 PM
