1999 Daewoo Lanos Torque
125,000 MILES • 4 CYL • 2WD • MANUAL
GRG4763
I have an a Daewoo Lanos 1.5. I need to know the torque for the crankshaft, piston rod and head valve.
Thank you in advance
Oct 15, 2010 at 1:54 PM
MADMIKE1735
  • 951 POSTS
i will be glad to help... not sure what exactly you need, your terms are a bit confusing... also, im getting only info on a 1.6l.... as far as crankshaft goes, im assuming you need the connecting rod torque to crank? thats 25 NM 1st stage, then an additional 30 degrees 2nd stage, and finally 15 degrees.... as far as head valve???? do you mean cylinder head? that is 25NM 1st stage... starting from middle outwards to each end... then 60 degrees, another 60 degrees, and another 60 degrees, then finally 10 degrees....
Oct 15, 2010 at 2:02 PM
