1999 Daewoo Lanos engine loosing power
ZZAHARI
1999 Daewoo Lanos Two Wheel Drive Manual 163000 miles
Hi. no trouble with ignition at first. but after i drive a few miles, the car engine is loosing power. then the engine will totally stop unless i stop at the roadside for a while. if the engine dies, then it will have the ignition problem. weird thing is, the engine is fine after that (that is why im thinking of electrical problem). this happened a couple of time already. anyone can help me? fuel filter problem? i bought this as a used car and the previous owner said it had a lead problem before but she already fixed it.
Apr 13, 2010 at 9:25 AM
ZZAHARI
miles is 262267. the previous in kms
Apr 13, 2010 at 9:29 AM
IZAMAN42
Try loosen the intake manifold bolts to let air to come out. If the car start, is the catalytic converter. I had same problem and replaced the catalytic converter, car now is good.
Jan 25, 2011 at 10:58 PM
