HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Daewoo
Lanos
Engine
Symptoms
Not Running
SPONSORED LINKS
1999 Daewoo Lanos Engine fires but wont start
KAYRITSON
MEMBER
1999 DAEWOO LANOS
4 CYL
2WD
MANUAL
330,000 MILES
My car will fire but the engine does not start, I have replaced the ignition leads, there is fuel in the tank
Thursday, April 15th, 2010 AT 2:52 PM
MECHANIC
Check the fuel pressure if its within specs-start here
SPONSORED LINKS
Thursday, April 15th, 2010 AT 3:38 PM
MYAK
MEMBER
Check your crankshaft sensor. I had a similar problem.
Monday, May 3rd, 2010 AT 6:22 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1999 Daewoo Lanos Car Won't Start
Replaced Battery, Sparkplugs Replaced And Fuel Injected Flued In Tenk, Motor Running Bur Car Won't Start. Already Checked Feul Pump...
Asked by
Mossie Eva
1 ANSWER
1999
DAEWOO LANOS
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1999 Daewoo Lanos Car Wont Start
Other Category Problem 1999 Daewoo Lanos Manual 112000 Miles Hi, I Bought A Daewoo Lanos Befote Xmas. It Will Start By Jump Or...
Asked by
holstiendrinker
1 ANSWER
1999
DAEWOO LANOS
1999 Daewoo Lanos Weak Spark, Crank No Start
Car Sputtered And Died On The Side Of A Road, Checked Fuel Delivery And Compression Both Are There Checked Spark And Its Very Weak...
Asked by
ajez19
1999
DAEWOO LANOS
1998 Daewoo Lanos Car Wont Start
Other Category Problem 1998 Daewoo Lanos Wheel Drive Type Unknown Manual 73000 Miles Hi I Bought Car Working Up To Couple Days Ago...
Asked by
haley37
1998
DAEWOO LANOS
2002 Daewoo Lanos Wont Start
Engine Performance Problem 2002 Daewoo Lanos The Battery Is Good, That Has Been Checked. It Only Starts When We Jump It And Then...
Asked by
blkwdw
2002
DAEWOO LANOS
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
