I have a 1.5ltr are there any special tools that I need to replace the timing belt. Do I need a timing belt tension gauge. How do I tell if the belt is at right tension, because the manual is telling me that the tension is set by the coolant pump, then the auto tensioner is installed.
Nov 25, 2009 at 5:05 PM
