1998 Daewoo Lanos no clutch
BUTTON
Transmission problem
1998 Daewoo Lanos 4 cyl Manual
i was driving home and i went to change gears and it made a noise like it does when you put it into gear
without using the clutch. I cranked it into 2nd as it wouldnt go into 1st and drove like that for bout
500 meters
Nov 12, 2008 at 5:40 PM
  • 75,988 POSTS
Check the clutch master cylinder fluid level, clutch slave/servo-no leakage-you might be looking at a new clutch assy-
Nov 12, 2008 at 6:55 PM
