1998 Daewoo Lanos Daewoo Lanos Cuts out with high revs when
50,000 MILES • 4 CYL • FWD • MANUAL
DAVID130589
Daewoo Lanos 1.6 sx cuts out when taken over 4000 rpm when cold and then will not start for 2 or 3 minutes. When it has been re-started it runs like a bag of nails for about 5 minutes and has no power. Seems to me that the engine is flooded and maybe the choke is stayin on longer than it should. Is there any thing i could do to stop this. Thanks Dave
Jan 27, 2008 at 5:41 AM
2CARPRO JACK
  • 11,533 POSTS
Is th echeck engine light on? if it is have it scanned at Autozone (they do it free) and get back with the codes. Does it just cut off or die off like it is running out of fuel?
Jan 27, 2008 at 11:55 PM
DAVID130589
No there are no engine lights that apear on the dash. it seems to run out of fuel or flood the engine. This only happens when it cold. As soon as it up to temp it runs fine. Thanks Dave
Jan 28, 2008 at 4:58 AM
2CARPRO JACK
  • 11,533 POSTS
So we need to know what is misisng when it is dead, spark, fuel or injector pulse
Jan 28, 2008 at 6:54 AM
