1998 Daewoo Lanos
ROD 73
Engine Mechanical problem
1998 Daewoo Lanos 4 cyl Front Wheel Drive Manual
coolant has just started to get into the oil cap has gone the milky colour looks quite thick, how long can it be driven for untill it can get into the mechanics to be repaired and is it dangerous to drive it around
Jun 27, 2010 at 2:58 AM
  • 31,937 POSTS
Hi there,
If you do a lot of short trips, this just may be excessive condensation as the engine is not reaching normal operation temp to burn it off, if you are experiencing coolant loss, i would have the head check for a problem ASAP.
mark (mhpautos)
Jun 27, 2010 at 3:02 AM
ROD 73
could it be just the a gasket blown or would it be head s for sure , and is still ok to drive around
Jun 27, 2010 at 3:11 AM
  • 31,937 POSTS
What you see is often just condensation, coolant in the oil will not just be in the cap it will start to turn the engine oil a thick coffee colour, if you have any doubts , get a head check done as this is a simple chemical test to prove exhaust gasses in the cooling system, a sure sign of a head or gasket problem, if this is the case it should be repaired ASAP.
mark (mhpautos)
Jun 27, 2010 at 3:21 AM
