2004 Daewoo Lacetti wont start
JAMES60601
2004 Daewoo Lacetti Front Wheel Drive Manual 60000 miles
my lacetti started but then stopped now wont start
Aug 26, 2010 at 12:15 AM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Aug 26, 2010 at 6:34 AM
FUAD NOR
I've replaced the camshaft and crankshaft sensors, distributor coil and spark plug cable set but the is no firing from it... what should I do then? power supply up to distributor is ok.
Mar 14, 2012 at 2:40 AM
