2004 Daewoo Lacetti wont start
2004 DAEWOO LACETTI
JAMES60601
2004 Daewoo Lacetti Front Wheel Drive Manual 60000 miles
my lacetti started but then stopped now wont start
Aug 26, 2010 at 12:15 AM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Aug 26, 2010 at 6:34 AM
FUAD NOR
I've replaced the camshaft and crankshaft sensors, distributor coil and spark plug cable set but the is no firing from it... what should I do then? power supply up to distributor is ok.
Mar 14, 2012 at 2:40 AM
