2004 Daewoo Kalos
JOAO CANDIDO
Electrical problem
2004 Daewoo Kalos 4 cyl Front Wheel Drive Manual
my car wors for about 10,20,30 minutes and stops,when i connect my scan machine,the code p0351 and p0352 appears.i already change ignition coil and crankshaft sensor.but still the same after he stops i have to wait for the nest day,then he works again.i already took off all the wiring and i cant find nothing damaged.can you help me
Feb 20, 2009 at 7:36 AM
DAVE H
  • 13,383 POSTS
have a dealer scan for codes it may be a fault on the PCM !!
Mar 20, 2009 at 2:36 AM
