2003 Daewoo Kalos Front wheel sensor for ABS system
75,000 MILES • 4 CYL • 2WD • MANUAL
KAZAMAC
My ABS light keeps coming on and the diagnostic check showed that this was due to a faulty front wheel sensor. The mechanic at the garage is unable to determine which of the 2 sensors are faulty as they have different readings and there is no guidance as to what the correct reading should be. Can you tell me what the correct reading for a front wheel sensor should be for the Daewoo Kalos?
Aug 3, 2009 at 9:33 AM
DAVE H
  • 13,383 POSTS
have another diagnostic check carried out .. there are different codes for each wheel ?
Sep 7, 2009 at 10:17 PM
