1996 Daewoo Cielo missing
ELVIS50
Engine Performance problem
1996 Daewoo Cielo 4 cyl Front Wheel Drive Automatic
can u help?
Jul 22, 2010 at 3:44 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jul 22, 2010 at 4:40 PM
