D4 light on dashboard flickers?
244,000 MILES • 4 CYL • AUTOMATIC
RABBITS3#
The D4 light on dashboard flickers lack of power when accelerating from stop to go. Could the possible cause be the transmission solenoid?
Feb 22, 2023 at 10:36 AM
RABBITS3#
Feb 22, 2023 at 10:40 AM
  • 55,721 POSTS
Yes, it could be, but we should run the codes in case the TCM is going out.
Here is a guide to help you:
https://www.2carpros.com/articles/honda-car-1990-1995-obd1-code-retrieval-procedure-and-definition-table
Let me know what you find. Also check the connection at the transmission to make sure they are secure. Here is the location of the TCM so you can check that out as well. Check the images below.
Feb 23, 2023 at 4:08 AM
