cylinders running very low compression
83,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALYSSA97
Two cylinders are running 30 psi, one cylinder is running 40 psi, the last cylinder is running 50 psi
Will insurance declare this as totaled?
May 8, 2019 at 7:22 AM
Good afternoon,
They will asses the value of the car based on miles and condition at the time of the appraisal.
Then they will price out the engine repair. If the bill exceeds 80% of the value of the car, then they will total the car.
May 8, 2019 at 7:32 AM
ALYSSA97
It is only valued at $3,000.00, but the mechanic said I will end up needing electrical work eventually down the road.
May 8, 2019 at 8:50 AM
ALYSSA97
And it’s also at around 85,000 miles.
The adjuster will not take that into consideration.
80% of the $3,000.00 is $2,400.00. A motor will cost more than that .
May 8, 2019 at 9:05 AM
ALYSSA97
May 8, 2019 at 9:30 AM
You are welcome.
Always glad to help.
May 8, 2019 at 9:35 AM
