Cylinders misfiring
127,000 MILES • 2.5L • 6 CYL • AUTOMATIC
GRINDTIME74
I having trouble finding out my exact problem. I start my car up and it runs kind of rough (shaky) in idle, then I see a flashing check engine light on my dashboard. Then it will illuminate solid and stay on. I went to AutoZone for the codes and it read all six cylinders are misfiring. I do not know why or what cause that to happen. Also sometimes I see more than usual clear or grey smoke coming out the exhaust pipes too! Any knowledge or suggestions?
Dec 6, 2018 at 3:32 AM
  • 110,248 POSTS
HI and thanks for using 2CarPros.
If you are seeing an excessive amount of white smoke from the exhaust, that is a concern. Often times, that indicates coolant is being burned in the combustion chamber. This is usually the result of a failed head gasket. Check to see if the coolant level is low.
First, take a look through this link. It discusses excessive smoke from the exhaust and causes. It shows pictures, so you can compare them to what you are seeing.
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
Take a look through this link. It discusses ways to determine if there is a head gasket problem.
I hope this helps. Let me know if you have other questions or if you feel this is not the problem.
Dec 6, 2018 at 12:08 PM
