Cylinder torque specs?
140,000 MILES • 2.2L • AUTOMATIC
TOUGHDIVER
  • 226 POSTS
Can someone give me cylinder head torque specs and sequence, please
And rocker arm torque specs?
Jul 26, 2026 at 1:44 PM
  • 55,721 POSTS
Sure, here are the torque specs for the cylinder head and rocker arm bolts.
Rocker Arm Bolts - 19 ft.lb
Important: The cylinder head bolts are torque-to-yield (TTY) and should be replaced with new bolts during installation.
Long Bolts - First Pass 46 ft.lb
Long Bolts - Final Pass 90 deg
Short Bolts - First Pass - 43 ft.lb
Short Bolts - Final Pass - 90 deg
Clean the bolt holes in the block before installing the new bolts. Any coolant or oil trapped in the holes can crack the block or give false torque readings. Let me know if you need anything else.
Jul 27, 2026 at 10:41 AM
