Cylinder order needed?
2013 AUDI A6
125,000 MILES • V6 • TURBO • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
I am getting conflicting reports on cylinder numbers. I have misfires on cylinder 4 and 5 and I am assuming they are on the right side starting from the radiator side. Can you confirm? This is a 6 3.0 supercharged.
Mar 4, 2023 at 1:55 AM
BHAMDOC1973
  • 2,007 POSTS
Nevermind it was correct. For some reason someone has been in there before, the bolts holding the connector to the valve cover are not there. Both coils 4 and 5 had a bent pin inside the coils, both at the same place, replaced coils all good.
Mar 4, 2023 at 8:04 AM
  • 55,381 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Mar 4, 2023 at 8:27 AM
