cylinder six misfire
145,000 MILES • 3.7L • V6
THOMAS WATSON
check engine light came on. Code reader said misfire cylinder six. replaced all the plugs with NGK gaped to .040. Same thing. double checked every thing then swapped coil pack from cylinder four. Same thing. However, the coil pack from cylinder six that I put on cylinder four was okay.
May 2, 2019 at 10:09 AM
Good evening,
You did the basic checks.
I would check the compression in the cylinder to be sure nothing is wrong internally.
Also, it could be a vacuum leak or an injector.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Apr 21, 2021 at 4:04 AM
