cylinder heads swap
120,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
WESSTERNER
  • 5 POSTS
want to know if regular 350 heads will fit on my big block Buick 350 motor?
Apr 13, 2020 at 10:42 PM
Good morning,
Please explain?
Big block for Buick is the 400, 430 and 455.
All the heads are different even with the 350 small block.
Apr 13, 2020 at 11:31 PM
WESSTERNER
  • 5 POSTS
It's a Buick 350 I am told it's a big block or stroker motor.
Apr 14, 2020 at 4:31 AM
Sorry, it is not. They were inaccurate. The 350 is a small block in the Buick line. the big block , as I stated, starts at the 400 and goes up to the 430 and the 455.
Apr 14, 2020 at 4:36 AM
WESSTERNER
  • 5 POSTS
I just googled to confirm
Apr 14, 2020 at 4:50 AM
Sorry, I grew up with these engines and rebuilt them and swapped them.
Irregardless , the heads will not work on any other engine. If you have this big block 350, you need the exact heads for that engine. Heads from any other engine will not fit.
Google is not the best information source for this. This is reality.
Apr 14, 2020 at 4:54 AM
WESSTERNER
  • 5 POSTS
Pontiac, Oldsmobile and Buick had them but not GM they have the same block as the 400 440 etc.
Apr 14, 2020 at 5:14 AM
Okay, sorry you disagree but you will get the same response if they know what they are talking about.
I am sorry you do not understand.
Apr 14, 2020 at 6:18 AM
WESSTERNER
  • 5 POSTS
Sorry, you are too lazy to double check.
Apr 14, 2020 at 8:54 AM
I am not lazy. I lived through those years and witnessed them first hand.
Hope you find your answer.
Apr 14, 2020 at 9:00 AM
