Cylinder head torque settings
90,000 MILES • 1.0L • 4 CYL
CBW27
  • 6 POSTS
I have the car listed above with an 8 valve 4 cylinder B10S engine. I am desperate need of the cylinder head torque settings.
Feb 28, 2020 at 7:09 AM
Here are the torque specs for the head:
25 Nm (18 ft lbs) + 60 + 60 + 60 + 15.
Thanks
Feb 28, 2020 at 7:48 AM
CBW27
  • 6 POSTS
Thanks , i appreciate it. I will get on with it tomorrow.
Feb 28, 2020 at 7:53 AM
Sounds great. Thanks for coming to 2CarPros. Please come back if you need other help. Thanks
Feb 28, 2020 at 8:10 AM
CBW27
  • 6 POSTS
I've been so stressed out about torque settings that I've forgot to ask for the valve clearances for the same car. can you help me with that please?
Feb 28, 2020 at 8:34 AM
Unfortunately, I could not find this for your model year. I had to go to a 2012 with the same engine so I am sure they would be the same.
Valve clearance (Intake: 0.075 - 0.125mm / Exhaust: 0.245 - 0.295mm)
Feb 28, 2020 at 8:55 AM
CBW27
  • 6 POSTS
Appreciate it , thanks again.
Feb 28, 2020 at 9:15 AM
