Cylinder head torque
108,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
BIGFISH1652
What is the cylinder head torque settings for the car listed above (f18d4)?
May 14, 2018 at 1:31 PM
Good morning.
Below is the procedure and attached is the sequence for tightening.
First pass to .................... 25 Nm (18 lb ft)
Second pass to .................... 90°
Third pass to .................... 90°
Fourth pass to .................... 90°
Fifth pass to .................... 45°
Surface Flatness - Block Deck - Longitude
If the deck surface is out of specification, replace the cylinder head. Do not machine the cylinder head.
Surface Flatness - Block Deck - Overall
Surface Flatness - Block Deck - Transverse
Camshaft Bearing Cap Bolt
Install the 8 intake camshaft bearing cover bolts and tighten in a spiral from the inside
to the outside to 8 Nm (71 lb in)
May 14, 2018 at 8:03 PM
