How to remove the cylinder head?
120,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
MARTY.MCCLEARTY
The Timing belt broke and bent valves, now I need to remove the heads, have a valve job and replace the heads.
Procedure for removing the heads with the engine in the vehicle would be very helpful.
Nov 7, 2022 at 9:37 AM
  • 110,251 POSTS
When you remove the head, make sure the pistons were not damaged. Check for cracks or anything that can prevent them from functioning as designed.
As far as the directions, I attached them below. You need to remove both the upper and lower intake manifolds. I added that in where it was needed.
See pics below. Also, let me know if you need help with the timing belt.
Nov 7, 2022 at 12:57 PM
MARTY.MCCLEARTY
I have another quick question.
On the bottom of the heads is a small (4") rubber gasket that is in a recessed channel.
Can you tell me a parts number for this gasket?
thank you
Nov 22, 2022 at 8:26 AM
  • 110,251 POSTS
I need to see a pic of this one. I don't recall there being a rubber gasket between the head and the cylinder head. I looked up head gasket kits and saw nothing that is approximately 4".
Is it possible for you to upload a pic of what you are seeing and upload it for me to see?
Nov 22, 2022 at 10:55 AM
MARTY.MCCLEARTY
Never mind Joe.
It is the gasket for the timing belt cover on the bottom of the cam plate. Sorry for the confusion.
Thank you !
Nov 22, 2022 at 9:25 PM
  • 110,251 POSTS
No problem whatsoever. I'm glad you got it figured out.
Take care and let me know how things turn out for you. Also, I hope you have a great Thanksgiving.
Nov 23, 2022 at 11:35 AM
