cylinder head bolt torque and sequence for 1.8 liter
130,000 MILES
STEVENELEWIS
need torque and sequence. have blown head gasket and want to replace myself.
May 24, 2013 at 4:58 AM
RACEFAN966
  • 5,029 POSTS
I see that a summit has either a 1.5 ltr or 1.6 ltr engine in 92. Either way you tighten from the center out in an x pattern. The 1.5 torque to 53 ft lbs. the 1.6 ltr you torque to 40 ft lbs then again to 80 ft lbs. Hope that helps.
Jun 17, 2013 at 1:14 AM
STEVENELEWIS
actually it is a 1.8 liter engine. Summit wagon DL
Jun 17, 2013 at 2:08 AM
RACEFAN966
  • 5,029 POSTS
Ok found it sorry it didn't show it the first time I looked it up. So sequence still the same middle out in an x pattern. Now the torque is as follows. Step 1 - 55 ft lbs, step 2 - fully loosen, step 3 - 14.5 ft lbs (yes that is correct), step 4 is 1/4 turn, final step is another 1/4 turn.
Jun 18, 2013 at 2:03 PM
