cylinder head bolt torque and sequence for 1.8 liter
1992 EAGLE SUMMIT
130,000 MILES
STEVENELEWIS
MEMBER
need torque and sequence. have blown head gasket and want to replace myself.
May 24, 2013 at 4:58 AM
RACEFAN966
✓Experienced Mechanic
I see that a summit has either a 1.5 ltr or 1.6 ltr engine in 92. Either way you tighten from the center out in an x pattern. The 1.5 torque to 53 ft lbs. the 1.6 ltr you torque to 40 ft lbs then again to 80 ft lbs. Hope that helps.
Jun 17, 2013 at 1:14 AM
STEVENELEWIS
MEMBER
actually it is a 1.8 liter engine. Summit wagon DL
Jun 17, 2013 at 2:08 AM
RACEFAN966
Ok found it sorry it didn't show it the first time I looked it up. So sequence still the same middle out in an x pattern. Now the torque is as follows. Step 1 - 55 ft lbs, step 2 - fully loosen, step 3 - 14.5 ft lbs (yes that is correct), step 4 is 1/4 turn, final step is another 1/4 turn.
Jun 18, 2013 at 2:03 PM
