Cylinder head bolt installation?
140,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
CSAUSA
I need to install the head bolts but need to know where the two smaller bolts go.
Sep 8, 2022 at 8:42 AM
BORIS K
  • 836 POSTS
2003 on 5.3 engines use 10 11mm head bolts which need to be replaced and 5 8mm head bolts which can be reused.
Tightening torque and degree:
11mm bolts, (1-10)
1st step: 22 ft/lbs
Next 2 steps you will need to use an angle gauge, see image 2
2nd step: (1-10) turn an additional 90 degrees
3rd step: (1-10) turn an additional 70 degrees
8mm bolts, (11-15)
22 ft/lbs, apply liquid Teflon paste or similar sealant to these bolts
See image 1 below for tightening sequence
Hope this helps,
Cheers, Boris
Sep 8, 2022 at 5:59 PM
