Cylinder seven misfire
200,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
SSHARPE
I have a repeated issue with cylinder seven misfiring. To begin with I changed the plug, it worked fine for a day or two and ended up having to change again, no change. At this point I have changed the plugs and wires, the ignition coil, and had a new head gasket done. I have not changed injector yet. Any suggestions?
Apr 21, 2022 at 10:46 PM
BORIS K
  • 836 POSTS
Is the engine misfiring at idle or under load? Is the misfire constant or intermitted?
How to check for misfire.
When doing a CAN scan what fault codes are set?
How to do a CAN scan.
Why was the head gasket replaced?
When you replaced the head gasket were the valves and rocker arms checked?
Have you checked the compression?
How to check compression.
and
https://youtu.be/J3j85hg0d-4
Symptoms and causes for low compression.
https://www.2carpros.com/articles/symptoms-of-low-compression
and
https://www.2carpros.com/articles/the-reasons-for-low-compression
The fuel injectors can be tested by using a suitable scan tool and fuel pressure tester and carrying out an injector balance test. Alternatively, injector testers and fuel pressure gauges can be purchased online, see images below. No expensive diagnostic tool is required.
See a good video.
https://youtu.be/I2IgGenAX0Q
and
https://youtu.be/QuknZ7KYBqs
Please let us know how you get along.
Cheers, Boris
Apr 22, 2022 at 1:34 AM
