Cylinder four misfire
117,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
LEXIMAY31
I've had a cylinder 4 misfire and cannot find the source. I have replaced the spark plugs, fuel injector and coils. The car also passed a compression test and does not ride rough at all.
Feb 13, 2020 at 5:47 AM
  • 110,248 POSTS
If compression is good, the plug is new, you have a new coil on it and it's working and a new fuel injector, the next thing I would be checking is fuel pressure. Too high or too low can be a cause.
Now, if you could provide a bit of info, it would help me. First, do you have the compression readings from all cylinders? Next, is it only a P0304 code you are getting? Next, do you lave a live data scanner? If you do, can you provide the short and long term fuel trims? Last, have you checked for an engine vacuum leak?
___________________________
Let me know as much as you can. I will watch for your reply.
Feb 13, 2020 at 9:55 AM
