cylinder 4 misfire
2002 ACURA MDX
165,000 MILES
TENNESHA93
Hello I have a 2002 Acura Mdx did a recent tune up because of cylinder misfire check light went off but came back on now it says cylinder #4 misfire changed the spark plug and coil light went away then came back on after I drove for a bit could it want a valve adjustment
May 28, 2013 at 11:40 PM
KHLOW2008
  • 41,814 POSTS
Yes, check the valve clearances and try swapping the injectors if the valve clearance adjustment does not work.
May 28, 2013 at 11:52 PM
TENNESHA93
Ok thanks I will let my mechanic know
May 28, 2013 at 11:57 PM
KHLOW2008
  • 41,814 POSTS
Any update on this?
Jun 13, 2013 at 4:29 AM
HONDATECH1983
  • 109 POSTS
Had one in the shop with a very similar situation. Turned out to be valve clearances were tight on several cylinders.
Nov 18, 2013 at 11:58 PM
