My check engine light is on for a cylinder 3 misfire, and I’ve already tried changing the spark plugs and the coils. The misfire is basically unnoticeable when you first start driving the car, but when the car stops (at a light or stop sign) for too long, the Traction Control light comes on and the misfire is impossible to miss as it basically jerks the entire car going out of first gear. This also sometimes causes the check engine light to blink instead of just staying on. I’m not sure what it could be?
Aug 2, 2023 at 5:13 AM
