Code P0303, cylinder three misfire?
240,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
JEFF HERMAN
  • 486 POSTS
There is engine code P0303. I did a coil swap with cylinder number 2. The misfire is still on cylinder number 3. I know these engines are notorious for the spark plug breaking off in the head, so I want to do every test possible before I do a compression test. I have a scanner that will read live data, but I know very little about how to read fuel trims, etc. It's a Foxwell NT630 plus and there is no tech support. Is there somewhere I can go to learn about how to diagnose this issue?
Oct 14, 2023 at 12:19 PM
AL514
  • 5,683 POSTS
Hello, swapping the coil and plug to another cylinder really is the first test I would do as well. You can try to do a cranking cadence test to see if you notice (by ear) if there might be a compression issue in that cylinder. You can first try holding the gas pedal to the floor and see if the vehicle has clear flood mode where it should turn off all the fuel injectors and you can listen to it just cranking (or unplug all the fuel injectors) to see if it has a smooth cranking sound or if it is an uneven type of sound that a low compression issue will make. Because with a cylinder that has low compression the crankshaft will speed up on that specific cylinder, and then slow down on the next one that has good compression. It will be an up/down type of sound. I'll see if I can find a video for you of it.
Another test you can do is a fuel injector balance test, where you will install a fuel pressure gauge on the rail and pulse each injector will a pulse tool for a certain number of milliseconds and watch how much pressure each injector drops. Ill post the tool for that as well, you can get one for around $30 on amazon, which will rule out the fuel injector without having to take out the spark plug.
I will usually get the engine hot before removing the spark plugs, the cylinder heads will expand just enough to help get the plugs out without having to worry too much about stripping the threads.
This is a picture of the injector pulse tool, it hooks to the battery and you prime the fuel system by key On, to get the pressure up where it should be, Fords have a nice port on the fuel rail to put a gauge on, then pulse the injector at one of the 3 settings, they are all just different amounts of time, I use number 2 which I think is 50ms of 2.5ms pulses. And you write down how much the pressure dropped. Then re-prime the system and do the next injector. They should all be within 1-2psi of each other. This basically tells you the flow rate of each one. If there is a problem with the one on number 3, you know it's the injector and not the spark plug.
The cranking cadence test is one you will have to get used to doing if it's the first time, it's like doing a relative compression test but without an oscilloscope.
Here is a video on a cranking cadence test. You can hear the sound clearly
If you have any questions or want to make a video of it cranking, you can post it here.
https://www.youtube.com/watch?v=pOghpmVhVng
This video is on doing an injector balance test, he's using an OTC tool, but the $30 tool does exactly the same thing, you just need to start the vehicle after going through all the injectors to get the unused fuel out of the cylinders. Just start it and let it run for a couple of minutes and you'll be good.
https://www.youtube.com/watch?v=l65gJSgVUGo
One other thing I wanted to mention, I own a Ford as well, and although it was not setting a misfire code for the #3 on mine, I did find in Mode 6 data, (which the data PID $53 is cylinder misfire detections) it was picking up misfires they were just not at a level high enough to set an OBD2 code (p0303), I did a smoke test on the intake manifold and found cylinders 2 and 3 the fuel injector seals were leaking, It was tough to find at first, but I was having positive fuel trim numbers (+12-15%) that would drop down to around (+2-3% which is fine) when the throttle was open, so I knew it was a vacuum leak. With closed throttle and high intake manifold vacuum, high positive fuel trim numbers usually mean a vacuum leak. But I sealed off the throttle body and Purge valve hose, and sure enough after a few minutes I eventually found smoke pushing out around the edges of #2 and #3 fuel injectors. Just wanted to share that since you had mentioned fuel trims.
Oct 15, 2023 at 1:02 AM
JEFF HERMAN
  • 486 POSTS
I will try the cadence test and I will see if any of the parts stores rent the injector pulse tool, or I'll consider buying one. It seems like it might be handy to have. The information on the vacuum leak around the injector o rings was very helpful. Thank you. I'm working on the truck for somebody who lives an hour away and I'm taking 10 days to head to the UP of Michigan so follow up may take some time. I'll definitely let you know what I find and I'll probably upload a video of the truck cranking.
Oct 15, 2023 at 10:45 AM
AL514
  • 5,683 POSTS
Okay, the injector pulse tool is a must have if you're going to be working on vehicles, there's no other way to do an injector balance test, checking just resistance won't tell if the injector is flowing correctly compared to the rest of them. I own one of the $30 ones and have been using it for years, also a smoke machine for checking for intake vacuum leaks or Evap system leaks is important too. Otherwise, it will be just throwing parts at a vehicle, which gets expensive real fast. So, it's worth investing in some gear even to repair your own vehicles. Saves a ton of money in the long run.
Oct 15, 2023 at 11:12 AM
JEFF HERMAN
  • 486 POSTS
How much is the smoke tester?
Oct 15, 2023 at 11:24 AM
AL514
  • 5,683 POSTS
It depends on which one you buy, google "smoke machine for cars" and a whole line will come up. You'll see there are some from $100 to over $1,000, but the cheaper ones work very well. Most hook up to an air hose from a compressor, but that can be too much pressure in most cases. So getting one that has a small build in air pump is best, for Evap system leaks, codes such as P0442 Evap control system small leak, P0456 small leak detected, P0455 large leak detected, P0457 which is a gas cap code but can be the gas tank filler neck leaking, the max pressure you can test the Evap system is 1 PSI. It's the small green cap on one vapor hose in the engine compartment that you'll notice. It's near the Purge valve on Fords. But you can't jam 20psi into a system like that because it will damage the Fuel tank pressure sensor. This is a good one that will hook up to a compressor but regulate the output pressure down to about 0.5psi which is good. I always have mine on hand for any mobile calls I go on. Hooks right up to the vehicle's battery.
https://www.amazon.com/AUTOOL-Automotive-Detector-Diagnostic-Compatible/dp/B0BGB41DLK/ref=asc_df_B0BGB41DLK/?tag=hyprod-20&linkCode=df0&hvadid=598354951676&hvpos=&hvnetw=g&hvrand=645330090606076898&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1021048&hvtargid=pla-1835201230545&psc=1
Oct 16, 2023 at 1:54 AM
