Code p0303 cylinder three misfire
252,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
FARR2007
  • 244 POSTS
I have a cylinder 3 misfire p0303.
Coil bolts are loose and one bolt on intake plenum.
Sep 10, 2020 at 3:10 PM
  • 110,248 POSTS
Have you trued to tighten the coil? Also, the bolt missing on the intake should be replaced as well.
Let me know what you need as far as directions. The idea that the coil and intake both have an issue, chances are one of the problems is causing the misfire.
Let me know what I can do to help.
Sep 14, 2020 at 10:25 AM
FARR2007
  • 244 POSTS
The bolt isn't missing, it's not supposed to come out and it's loose and when tighten.
Sep 14, 2020 at 10:26 AM
  • 110,248 POSTS
It sounds like it is stripped. Can you upload a pic of where it is located and then a close up of the threads so I can see it?
Sep 14, 2020 at 11:54 AM
FARR2007
  • 244 POSTS
Can't see threads it is under the plenum.
Sep 14, 2020 at 11:55 AM
  • 110,248 POSTS
What I would suggest is to remove the intake. If the bolt is stripped, an air leak can be causing the misfire. By chance, is the bolt that is loose near cylinder 3?
________________________________
Here are the directions for the upper intake. The attached pics correlate with the directions.
2001 Mazda Truck Tribute LX 4WD V6-3.0L DOHC
Upper Intake Manifold
Vehicle Engine, Cooling and Exhaust Engine Intake Manifold Service and Repair Procedures Upper Intake Manifold
UPPER INTAKE MANIFOLD
Removal
pic 1
1. Remove the air cleaner outlet tube.
1. Remove the vacuum hose.
2. Loosen the clamps.
3. Remove the air cleaner outlet tube.
pic 2
2. Remove the three nuts and the engine appearance cover.
pic 3
3. Disconnect the cables.
1. Disconnect the throttle cable.
2. If equipped, disconnect the cruise control cable.
3. Remove the throttle cable bracket bolts.
pic 4
4. Disconnect the throttle position (TP) sensor and idle air control (IAC) electrical connectors.
pic 5
5. Disconnect the exhaust gas recirculation (EGR) valve vacuum hose and EGR tube nut.
pic 6
6. Disconnect the EGR vacuum regulator valve electrical connector and vacuum hose.
pic 7
7. Disconnect the three vacuum hoses on the back of the intake manifold.
1. Connect the chassis vacuum hose.
2. Connect the engine vacuum hose.
3. Connect the positive crankcase ventilation (PCV) hose.
pic 8
8. Disconnect the vapor management valve (VMV) vacuum hose.
pic 9
9. Disconnect the two electrical connectors attached to the left side of the upper intake manifold.
pic 10
10. Disconnect the power steering pressure (PSP) sensor electrical connector.
pic 11
11. Remove the eight bolts and the upper intake manifold.
1. Remove and inspect the gaskets. Discard if damaged.
2. Clean all sealing surfaces.
Installation
1. Position the gaskets in the upper intake manifold.
pic 12
2. Position the upper intake manifold and tighten the bolts in the sequence shown.
pic 13
3. Connect the PSP electrical connector.
pic 14
4. Install the two electrical connectors on the left side of the intake manifold.
pic 15
5. Install the vapor management valve (VMV) vacuum hose.
pic 16
6. Connect the three vacuum hoses on the back of the upper intake manifold.
3. Connect the PCV hose.
pic 17
7. Connect the E.G.R. Vacuum regulator electrical connector.
pic 18
8. Install the EGR valve vacuum hose and EGR tube nut.
pic 19
9. Connect the TP sensor and IAC electrical connectors.
pic 20
10. Connect the throttle cables.
1. Install the throttle cable bracket bolts.
2. Connect the throttle cable.
3. If equipped, connect the cruise control cable.
pic 21
11. Install the air cleaner outlet tube.
1. Position the air cleaner outlet tube.
2. Install the hoses.
3. Install the clamps.
pic 22
12. Install the splash shield.
_______________________________________________________
Lower intake:
Lower Intake Manifold
Vehicle Engine, Cooling and Exhaust Engine Intake Manifold Service and Repair Procedures Lower Intake Manifold
LOWER INTAKE MANIFOLD
Removal
1. Disconnect the fuel line spring lock coupling.
Pic 23
2. Remove the upper intake manifold.
pic 24
3. Disconnect the fuel rail.
1. Disconnect the six fuel injector electrical connectors (1).
2. Disconnect the fuel pressure damper vacuum line (2).
4. Remove the bolts and the lower intake manifold.
pic 25
5. Remove the fuel rail.
1. Remove the bolts (1).
2. Carefully separate the lower intake manifold from the fuel rail (2).
6. Remove the six fuel injectors from the lower intake manifold.
7. Remove and discard the gaskets if damaged.
Installation
1. Install the gaskets in the lower intake manifold.
CAUTION: Never use silicone grease. It will clog the fuel injectors.
NOTE: Inspect the fuel injector O-ring seals and install O-ring seals if necessary.
2. Lubricate the O-ring seals lightly with SAE 5W-20 Motor Oil and install the fuel injectors into the lower intake manifold.
pic 26
3. Install the fuel rail.
1. Position the fuel rail (1).
2. Install the four bolts (2).
pic 27
4. Install the lower intake manifold assembly and tighten the bolts in the sequence shown.
pic 28
5. Connect the fuel rail.
1. Connect the six fuel injectors (1).
2. Connect the fuel pressure damper vacuum line (2).
6. Install the upper intake manifold.
7. Connect the fuel line spring lock coupling.
Have you been able to secure the coil?
Sep 14, 2020 at 12:32 PM
FARR2007
  • 244 POSTS
Here is the bolt on the front of engine:
Sep 14, 2020 at 12:41 PM
  • 110,248 POSTS
Is that the one that can't be tightened? If so, are you able to remove it? It looks like there is room.
Sep 14, 2020 at 12:53 PM
FARR2007
  • 244 POSTS
No those bolts are not made to come out.
Sep 15, 2020 at 9:28 AM
  • 110,248 POSTS
We have two choices here. First, replace or repair the ignition coil for cylinder 3 to see if that eliminates the problem. If it doesn't, check the intake for vacuum leaks. I suspect there could be one simply because the bolt can't be tightened.
If it was me, I would tighten the loose coil and see if that chances it.
Sep 15, 2020 at 12:00 PM
