Cylinder five misfire
120,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
CHASE RIDDLE
I have the car listed above GT model. it has a code p0305. I replaced the spark plugs, ignition coils, and injector. What could be the problem?
Nov 22, 2018 at 11:23 PM
Good evening,
The misfire could be from many reasons.
Below are some possibilities.
1. Low compression. There could be worn rings, burned valve or head gasket. This needs to be verified by a shop that will do the proper diagnostics.
2. Vacuum leak. A smoke leak will tell if there is a leak around cylinder five.
3. Injector not being commanded to fire from a failed PCM. A shop can use a noid light to confirm this. Easy check.
Nov 23, 2018 at 6:10 AM
