Do I need to reset the timing after replacing the cylinder head
240,000 MILES • 4 CYL • 2WD • AUTOMATIC
STACY ZIMMERMAN
  • 26 POSTS
Just replaced head gasket and picked up a another head for my car. My question, do or will i need to reset the timing now? I didn't move my timing but had to remove the rocker arm assembly to tilt it to get my timing belt back on. 1st time working on this car so not sure if i just caused another problem or not. If so how do reset the timing now? Or do i wait to see if will start 1st?
Aug 29, 2020 at 6:51 AM
  • 110,246 POSTS
This is an interference engine, so you have to be sure the timing is correct. If it is off, it can cause internal damage to the engine.
You indicated it is a 4 cylinder engine. I need to know if it is a 2.3L single overhead cam, dual overhead cam or exactly what it is so I can provide the correct directions.
Aug 29, 2020 at 7:07 AM
STACY ZIMMERMAN
  • 26 POSTS
Will this help? I'm at work will have to get more info when get home.
Aug 29, 2020 at 7:13 AM
  • 110,246 POSTS
I'm not sure what is in the picture. When you get a chance, just let me know. I'll be here.
Aug 29, 2020 at 7:32 AM
STACY ZIMMERMAN
  • 26 POSTS
Okay, thanks. will do.
Aug 29, 2020 at 7:33 AM
STACY ZIMMERMAN
  • 26 POSTS
Picture of number on block F23A1.
Aug 29, 2020 at 8:05 AM
  • 110,246 POSTS
That appears to be a 2.3L. Here are the directions I have for it. These are for the single overhead cam engines. If you have something different, let me know.
These directions are from start to finish. The attached pics correlate with the directions. They will indicate timing marks.
____________________________________________________
2002 Honda Accord DX Sedan L4-2254cc 2.3L SOHC MFI
Procedures
Vehicle Engine, Cooling and Exhaust Engine Timing Components Timing Belt Service and Repair Procedures
PROCEDURES
Timing Belt and Balancer Belt
Removal
Special Tools Required
- Holder Handle 07JAB-001020A
- Holder Attachment, 50 mm, Offset 07MAB-PY3010A
- Socket, 19 mm 07JAA-001020A or a commercially available 19 mm socket
1. Make sure you have the anti-theft code for the radio, then write down the frequencies for the radio's preset buttons.
2. Disconnect the battery negative terminal first, then the positive terminal.
pic 1
3. Turn the crankshaft pulley so its TDC mark (A) lines up with the pointer (B).
4. Remove the front tires/wheels.
pic 2
5. Remove the splash shield.
pic 3
6. Loosen the mounting bolts (A), then remove the P/S belt (B).
pic 4
7. Disconnect the alternator wire harness.
- 1 Pull up the lock (A), then release the wire harness tie (B).
- 2 Pull back the boot and remove the 6 mm nut (c).
- 3 Disconnect the connector (D) from the alternator.
8. Remove the alternator.
9. Remove the alternator bracket.
10. Support the engine with a jack and wood block under the oil pan.
pic 5
11. Remove the stopper (A) and ground cable (B), then remove the upper bracket (C).
12. Remove the cylinder head cover.
pic 6
13. Remove the upper cover.
pic 7
14. Remove the dipstick and tube (A). Discard the O-ring (B).
pic 8
15. Hold the pulley with holder handle (A) and holder attachment (B).
16. Remove the bolt with a heavy duty 19 mm socket (c) and breaker bar.
pic 9
17. Remove the rubber seal from the adjusting nut, then remove the lower cover.
18. If you are removing only the balancer belt, go to step 19. If you are removing both the balancer belt and the timing belt, go to step 20.
pic 10
19. Release tension from the balancer belt:
- 1 Install a 6 mm bolt (A)(from the timing cover) through the hole in the end of the timing belt adjuster arm to temporarily lock the arm in place.
- 2 Loosen the adjusting nut (B) 2/3 - 1 turn.
- 3 Push the tensioner (c) up to take tension off the balancer belt.
- 4 Retighten the adjusting nut (B).
pic 11
20. Release tension from the balancer belt and the timing belt:
- 1 Loosen the adjusting nut (A) 2/3 - 1 turn.
- 2 Push the balancer belt tensioner (B) up to take tension off the balancer belt.
- 3 Push the timing belt tensioner (c) down to take tension off the timing belt.
- 4 Retighten the adjusting nut (A).
21. Remove the balancer belt.
22. Remove the timing belt.
Installation
NOTE:
- If you are installing the timing belt and the balancer belt, go to step 1.
- If you are installing only the balancer belt, go to step 7.
1. Remove and clean the balancer belt drive pulley.
2. Clean the timing belt pulleys, and the upper and lower timing cover.
pic 12
3. Set the crankshaft to TDC. Align the dimple (A) on the tooth of the timing belt drive pulley with the pointer (B) on the oil pump.
pic 13
4. Clean the camshaft pulley and set it to TDC.
- 1 The "UP" mark (A) on the camshaft pulley should be at the top.
- 2 Align the TDC grooves (B) on the pulley with the too edge of the head.
pic 14
5. Install the timing belt in a counterclockwise sequence, starting with the drive pulley.
- 1 Drive pulley (A).
- 2 Tensioner pulley (B).
- 3 Water pump pulley (C).
- 4 Camshaft Pulley (D).
6. Loosen and retighten the adjusting nut to tension the timing belt.
7. Clean any oil off both faces of the balancer belt drive pulley.
8. Check the lower cover rubber seal for cracks and other damage.
NOTE:
- If the rubber seal is coming off, apply liquid gasket to the lower cover and reinstall the rubber seal. Wipe off any liquid gasket that is pressed out.
- When replacing the rubber seal, clean the lower cover groove, cut the repair rubber seal to length, and put the rubber seal into the groove evenly.
9. Install the balancer belt drive pulley and the lower cover.
10. Temporarily install the crankshaft pulley and bolt.
11. Rotate the crankshaft pulley five or six turns counterclockwise to seat the timing belt on the pulleys.
pic 15
12. Adjust the belt tension.
- 2 Rotate the crankshaft counterclockwise three teeth on the camshaft pulley (B).
- 3 Tighten the adjusting nut to 44 Nm (4.5 kgf-m, 33 ft. lbs.)
pic 16
13. Turn the crankshaft pulley so its TDC mark (A) lines up with the pointer (B).
pic 17
14. Check the camshaft pulley marks.
- If the camshaft pulley marks are also at TDC, go to step 15.
- If the camshaft pulley marks are not at TDC, remove the timing belt and repeat steps 3, 4 and 5.
15. Remove the crankshaft pulley and the lower cover.
16. Turn the crankshaft to TDC again.
17. Lock the timing belt adjuster arm in place with one of the 6 mm timing cover bolts.
18. Loosen the adjusting nut 2/3 - 1 turn, and make sure the balancer belt tensioner moves freely. Then push the tensioner up and retighten the adjusting nut.
pic 18
19. Align the rear balancer shaft pulley with a 6 x 100 mm bolt (or equivalent).
- 1 Remove the bolt (A) and washer (B) from the maintenance hole (C).
- 2 Scribe a line on a 6 x 100 mm bolt, 74 mm (2.9 inch) from the end.
- 3 Insert the bolt in the maintenance hole and into the hole in the balancer shaft (D) up to the line you scribed.
pic 19
20. Align the groove (A) on the front balancer shaft with the pointer (B) on the oil pump housing as shown.
21. Install the balancer belt. Loosen the adjusting nut 2/3 - 1 turn to tension the balancer belt. Retighten the bolt.
22. Remove the 6 x 100 mm bolt from the maintenance hole and reinstall the sealing bolt. Tighten the bolt to 29 Nm (3.0 kgf m, 22 ft. lbs.).
23. Adjust the balancer belt.
- 1 Temporarily reinstall the crankshaft pulley.
- 2 Loosen the adjusting nut 2/3 - 1 turn.
- 3 Turn the crankshaft pulley 1 turn counterclockwise, then tighten the adjusting nut.
24. Remove the 6 mm bolt from the timing bolt adjuster arm.
25. Check the lower cover rubber seal for cracks and other damage.
NOTE:
- If the seal is coming off, reattach it with liquid gasket. Wipe off any excess liquid gasket.
- When replacing the seal, clean out the groove in the cover, cut the repair strip to length, and press the new piece into the groove.
26. Remove the crankshaft pulley and reinstall the lower cover.
27. Install the rubber seal around the adjusting nut.
28. Clean the crankshaft pulley bolt and washer.
pic 20
29. Clean all oil off the inside face (A) of the crankshaft pulley, and apply lubricant to the pulley bolt (B) and washer (C).
pic 21
30. Install the crankshaft pulley, and hold with holder handle (a) and holder attachment (B).
31. Tighten the bolt to 245 Nm (250 kgf-m, 181 ft. lbs.) with a torque wrench and 19 mm socket (c). Do not use an impact wrench.
pic 22
32. Install the dipstick and tube (A) with a new O-ring (B).
pic 23
33. Install the upper cover.
34. Install the cylinder head cover.
35. Install the alternator bracket.
36. Install the alternator.
37. Connect the alternator harness.
38. Install and adjust the power steering pump belt.
39. Install and adjust the alternator belt.
pic 24
40. Install the upper bracket (A), then tighten the bolt and nuts in the numbered sequence shown.
41. Install the stop (B).
42. Install the battery. Clean the battery posts and cable terminals with sandpaper, then assemble them and apply grease to prevent corrosion.
43. Enter the anti-theft code for the radio, then enter the customer's radio station presets.
Let me know if this helps or if you have other questions. Since you already have the cylinder head off, this is a good time to replace the belt.
Aug 29, 2020 at 2:01 PM
STACY ZIMMERMAN
  • 26 POSTS
I had belt replaced about 40,000 miles ago when i put had put this engine in. I'm just needing to know how to reset the timing. Not sure if i need to but i had to remove the rocker arm assembly and tilt it a little to get the drive belt back on the wheel. I did mark the wheel I make sure i got it back in same spot but may be off a little. This isn't the original head for the motor. So i am assuming it needs to be timed so i did not break or cause any damage.
Aug 29, 2020 at 8:36 PM
  • 110,246 POSTS
Stacy, I just sent all the info to you. If you look at pics 16 and 17, they show where the timing marks should be. I hope I didn't overwhelm you with the info. I just wanted to give you everything.
Are the marks on the crank and cam the same as the pic?
If you are worried they may be off, get them to where you feel they are right and then turn the engine by hand (breaker bar on crank bolt) to make sure it turns smoothly and nothing stops it from turning.
Let me know. Also, let me know if you have other questions.
Aug 30, 2020 at 1:55 PM
STACY ZIMMERMAN
  • 26 POSTS
No, you helped.
Reading sometimes from manual is more confusing, lol.
Aug 31, 2020 at 9:12 AM
STACY ZIMMERMAN
  • 26 POSTS
Okay, got marks set on crank an cam pulley, but i'm having issues trying to line up the cam bolt holes on top. they're off about a 1/16 maybe. i removed the top with rocker arms so I could get timing belt back on.
Sep 1, 2020 at 2:04 AM
  • 110,246 POSTS
If you are unable to align the bolts for the cam sprocket, then the camshaft must need turned a bit. Have you tried that?
Sep 1, 2020 at 11:43 AM
STACY ZIMMERMAN
  • 26 POSTS
Think so.
I gave up put the old head back on. Now i'm trying to get balancer off with small air compressor with no luck yet.
So can get in time but cant get belt on unless remove plastic cover to get to belt tensioner to release still i can hey belt over cam pulley.
Sep 1, 2020 at 1:03 PM
  • 110,246 POSTS
I'm not sure I understand. What are you trying to do?
Sep 1, 2020 at 1:14 PM
STACY ZIMMERMAN
  • 26 POSTS
need to access the timing belt tensioner so I can get some slack to put timing belt back on. from what videos i have seen that's how I have to do it.
the balancer on outside has marks an I can find top dead center just can't get belt on. doubt my impact will get it off so not sure what to do keep hitting it with my impact an maybe can get itr loose, idk.
Sep 1, 2020 at 9:47 PM
  • 110,246 POSTS
Stacy,
Take a look at the attached pic. Is that what you are working with?
Sep 2, 2020 at 11:32 AM
