Cylinder one misfire when starting warm
242,000 MILES • 3.4L • V6 • 4WD • MANUAL
TACOMACODY
When I start the truck cold it starts up great and can run great as long as I do not turn it off. If I turn it off when it is warm and try starting it again while warm it will not fire on cylinder one. It has new wires, plugs, coils. I have been told vacuum leak, but would a vacuum leak effect all cylinders?
Help!
May 12, 2018 at 11:39 AM
JIS001
  • 3,412 POSTS
Here is an article that may help you diagnose your misfire:
Performe these tests when the vehicle is warmed up to duplicate the concern. Let us know what the readings are please.
May 12, 2018 at 4:41 PM
