CVVT timing?
200,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
BENTONJAMES
I changed timing belt, and started it running, but the engine won't rev up, it does but no power. all timing marks are in line. Any suggestions?
Nov 15, 2022 at 2:12 AM
  • 55,697 POSTS
It sounds like the engine is in limp mode, I would service the throttle bore and make sure the air intake system has no leaks. Also, we should run the codes as well, this guide can help:
and
We should double check the timing belt timing as well here are the marks in the images below. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Nov 16, 2022 at 2:41 AM
BENTONJAMES
I've checked all timing marks 3 times now perfect. I started it and sprayed starting fluid all around the intake system. still won't rev up any it will idle scanned codes. none. Do you have any more suggestions?
Nov 18, 2022 at 2:42 AM
BENTONJAMES
I am getting frustrated, i am a retired journeyman diesel mech.
Nov 18, 2022 at 2:45 AM
  • 55,697 POSTS
I assume the engine ran okay before the job was done. Do you have all of the ground wires back on the engine? The upper cam gear alignment hole is at 12 o'clock, correct?
Nov 18, 2022 at 7:36 AM
