Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Drivetrain
Transmission
Replace/Remove
CVT transmission replacement I need to install?
2014 TOYOTA COROLLA
45,990 MILES • 1.5L • 4 CYL • 4WD • AUTOMATIC
WAYNE EDWARD
MEMBER
1 POST
I have a Japanese Toyota Axio 2011 with a bad four wheel drive CVT transmission. I need to install it can you help?
Jan 1, 2018 at 3:17 AM
Experienced Mechanic
No problem. Here are the instructions from the manual that will help with replacing the transmission on this vehicle.
Also, here is a guide that will help with replacing an automatic. While this is a CVT it is still similar to this process.
https://youtu.be/3vJAojsrfuU
Below is the process from the manual that will help. Please let us know if you have other questions. Thanks
Images (Click to enlarge)
Apr 28, 2021 at 11:26 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
