When traveling on the interstate over seventy-five miles per hour the transmission overheats under seventy-five miles per hour no issues appear.
Jul 12, 2025 at 5:01 AM
✓Experienced Mechanic
Oh yes, that is because the fluid needs to be changed, when the fluid wears out the transmission will slip causing this "overheating" here is how to change the fluid and only use.
