cv joints are bad
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
RICHARD TICKNER
Hi, just wondering when replacing CV joint on the vehicle listed above AWD does the emergency brake cable get disconnected?
Nov 25, 2020 at 6:49 AM
Here is a guide that will help replacing this. This is for the front end, but it does have good info with it.
https://www.2carpros.com/articles/replace-cv-axle
I am also attaching the info from the manual below on the rear axles. You need to remove the caliper, but it appears the cable can stay attached.
Please run through this info and let us know what other questions you have. Thanks
Oct 5, 2021 at 7:42 AM
