cv joint removal and wheel bearings
15,800 MILES
PAPARAY
i cannot get the drivers side cv joint to seperate from the transmission there doesn't seem to be a pin or clip holding it i didn't want to beat it out unless i was sure,and i can't get the rotor seperated from the the wheel bolt pattern to put new wheel bearing in
Oct 7, 2013 at 12:30 AM
HMAC300
  • 48,601 POSTS
what are you trying to do remove both? you then take the large nut loose the large nut off prior to jacking car up. then take off tire, brake stuff and remove wheel bearing. if removing axle sometimes you need to remove the lower ball joint from strut so there is enough room to pull axle out then get a large screwdriver /bar and pry out axle from transmission.
Oct 7, 2013 at 12:34 AM
