Depends on the cause. If this was a Ford product, I would recommend bailing out and walking as separated ball joints are much too common. On other brands, light metallic sounds are usually not related to safety systems, but you need to be sure. The best approach is to have the steering and suspension systems inspected at a a tire and alignment shop. The people there are experts at finding the causes of noises, vibrations, and bad tire wear.
You need to add a lot more detail to your description. Does this noise occur when turning left and the car is standing still, or does it have to be moving? If it must be moving, how fast? Noises when turning and standing still are usually caused by a binding upper strut mount, which is typically not a safety hazard unless it makes it difficult to turn, but it can be caused by a ball joint too. If a ball joint separates, there is a good chance you will go sailing into the ditch or into oncoming traffic.
A common cause of a light rattle, like from a tambourine, is deteriorated bushings on the anti-sway bar links. That is not a safety hazard other than it allows the car to lean more when cornering. You will hear this when driving over bumps in the road.
Why did you mention the CV joint boot? At the mileage you listed it is not uncommon to have a worn outer CV joint. Those will make a clicking noise when turning and the car is moving, but most commonly they make that noise when backing up. The rubber boot pushes grease into the steel marbles as it rotates, and it keeps dirt and water out. The marbles, and the grooves they run in are machined very precisely and to very close tolerances. It does not take much wear for them to bind and cause a clicking noise.
Dec 20, 2017 at 7:55 AM
