CV axle replacement
155,000 MILES • 3.0L • 6 CYL • AUTOMATIC
BAKER98
When I drive, I have to keep the steering wheel slightly to the left, otherwise it starts to shake and I hear a knocking sound. Could this be my CV joint? I went under and the left seems solid, but the right side I can move it left and right a couple inches. Is it the CV joint? Or something else?
May 4, 2021 at 7:54 PM
Good morning,
Yes, it sounds like the CV joint is worn out.
https://www.2carpros.com/articles/replace-cv-axle
I would replace the entire axle assembly. They are reasonable in price these days. I attached the procedure for you below.
I also attached the axle shaft from Rock Auto for you to view.
Jun 8, 2021 at 6:52 AM
BAKER98
I highly appreciate the answer. I’ll go ahead and gets the parts in and I’ll let you know if that fixes the problem here within the next couple of days. Thank you!
You are welcome.
Always glad to help.
